Sponsored by: DashLynx
Bulb to LED List
Old 08-02-2009, 04:54 PM
fbodyrs96's Avatar
yeah, there twist and lock, the new LED fits just like it should but the contact points on the socket are on the ends and the LEDs are on the sides so they don't match up right.
this i how I did it the 1st time, I have sense switch to the WLEDx5 much better light output.
Old 08-02-2009, 08:01 PM
DropTopBird's Avatar
Yeah we did the WLED-x5, but we broke the leads off of two of the LEDs. They are a lot more fragile than they look.
Old 08-09-2009, 07:39 PM
ZexGX's Avatar
Would those work for the headunit back light? The ones for the headunit are nearly identical but the base has a flat top so that it can slide into the headunit. It is a neo-wedge bulb like that - I think T4 but I'm not sure.
Old 08-09-2009, 08:43 PM
fbodyrs96's Avatar
I have no idea, that's a 194 led, just order a few and try them, if you order in small test samples they will accept returns or so I read.
Old 08-10-2009, 04:18 AM
ZexGX's Avatar
I think this one is the one I'm looking for. I could be wrong though. The only way to be sure is when I get a chance to open up the headunit and measure the base of the bulb in millimeters.
Dual High Powered LED
Type B (T4)
79674-S3N-941
79607-SHJ-S01
10mm= 3/8"
$3.99 ea
Old 08-10-2009, 10:13 PM
KLaBZ28's Avatar
I did the same thing when I bought mine, and there not plug and play on the 93-96 camaro, the stock bulb is solder to the plug, so you have to break them out and pull the leads up off the LED base and wrap around the metal brackets to make them work.
nice well i got the WLED- HP6 and guess i cant use those now...
Old 08-10-2009, 10:14 PM
camaro_ss_97's Avatar
whats the best and cheapest place to buy leds?
Old 08-13-2009, 10:58 PM
LS1babe's Avatar
great list !! ill be doing the interior soon!
Old 08-13-2009, 11:17 PM
FL Junkie's Avatar
ebay. you can find them alot cheaper.
Old 09-12-2009, 08:05 PM
YORK_MUSTAINE's Avatar
very good info
Old 10-08-2009, 07:31 PM
rcoers's Avatar
For the dome lights you put a fixed loop festoon, is this the same as a rigid loop?
Old 01-20-2010, 11:48 PM
  #32
Ws6kid.'s Avatar
thank you!
Old 01-22-2010, 01:04 PM
  #33
Quick86's Avatar
Has anyone converted their tail lamp bulbs to LED's? Also, how about the back up lamps and the license plate lamps?
Old 01-26-2010, 10:52 PM
  #34
ws6dude's Avatar
Great thread
Old 01-26-2010, 10:54 PM
  #35
Ls1CamaroGuy87's Avatar
Brake lights and my entire interior (red) here Don't forget that you have to add resistors and a flasher for the turn signals and hazards...
Old 01-27-2010, 04:15 PM
  #36
i use leds in all my trans am ws6 i will take pics to post it
Old 01-29-2010, 09:31 AM
  #37
Quick86's Avatar
Please do post pics! I'd love to see them!
Old 01-29-2010, 10:50 PM
  #38
tomorrrow nite i will post my ledsĦĦĦĦ
Old 02-01-2010, 12:26 AM
  #39
jdoyle's Avatar
I have a '99 Z with a stock gauge cluster.
I want to replace my gauge cluster bulbs with LEDs and want to keep the stock color scheme and was wondering if I need to get colored LEDs or simply white ones to keep the stock look of my gauge cluster.
I know that I should get some WLED-HP6 LEDs and that I will need to grind the tops down to make the fit/shine properly.
Thanks for the help.
Old 02-01-2010, 01:09 AM
  #40
HoLLo's Avatar
The Sylvanias site isnt 100% accurate. For example, the reverse lights are 3156 not 1156
Quick Reply: Bulb to LED List
