help...if you have installed a Sparco Wheel on your column
8 Second 6 Speed Director
Location: windsor, ont. canada - Home of the fastest LT1 6spd.
1 Post
i am amidst swapping steering wheels, i have the wheel off and have bought the hub adapter and wheel. i even got the quick disconnect, but am not sure if i am going to use it at this point.
anyhow, i was looking at the hub adapter after removing the wheel, and wondered if i need to removed the clock spring assembly associated with the SRS system? any help is greatly appreciated!
regards,
taner
regards,
taner
Damn. Wish I could help you but I didn't install mine.
I too have the quick connect with an extension. Nice piece!
I can tell ya the horn is a biatch! You have to run a separate ground wire. Then every time you disconnect the wheel you need to disconnect the pinch wire to the horn.
Good luck
Good luck
