Im looking for TA "Low rise" to "High rise" spoiler how to.....
I have a 96 ta that came with a low rise spoiler,,, I want to switch to the high rise,,, i heard I need to swap the whole hatch... is this true?? and do i need the full high rise hatch including glass,,,, how is the glass attached to the hatch? Has anyone done this and is there any good how to threads around. thanks
Is the low rise attached to the hatch like on a Firebird? Or is it a Firehawk spoiler? If its a Firehawk style then you just need to get a high rise, but if not then you need the entire hatch.
I don't believe the 1996 T/A's had the low-rise hatch available from the factory.
(Well, I guess I was wrong, ..., but man enough to admit it, ..., at least that's what my wife keeps tellin' my anyway, ..., that I was wrong, ...)
Whole Hatch.
Done.
Yes, it's true. You need to swap the entire hatch. If you have a common color (like red/white/black) your job is pretty easy since you can just find one off a T/A that's the same color and swap it straight up.
It would be easiest on you if you got one with the glass installed. The glass is basically held in with a kind of glue (I believe it's called Ribbon Sealer) so it would need to be installed by a professional if the glass is not in it.
Do a quick search, many have done this swap. Like this guy.
He specifically said '96 T/A, so I would assume it has the 'Firebird/Formula' style spoiler on it now. Which is kinda surprising. I wonder if it was a Formula & someone added the T/A front bumper & side skirts. Or it was a T/A & someone replaced the hatch before because of an accident or something.
Whole Hatch.
Done.
Whole Hatch.
Done.
Whole Hatch.
Done.
Whole Hatch.
Done.
yah i was told it may depend on the rear gear... but i dont have the car here to see what gear i have. I also know another guy that has a ta with a low rise also... wierd cause i dont see any on here.
I know where theres a full hatch with glass... but he wants like 300 for it... i was ganna offer alot less...or find one with busted glass so i can get a deal on it... but its prob more bs then i need... dont think i wanna mess swaping glass myself.
It's an easy swap man. Open hatch, pull headliner down disconnect connectors, undo ground. Undo bolts on the two latches. Take off struts (make sure you're holding the hatch up) and lift and remove.
If you can carry ~100lbs for a min on your own, you can do it yourself easily. The lowrise hatch is WAY lighter than the high-rise TA hatch.
I pretty much did the swap myself. But asked for a helping hand when installing the high-rise hatch because I didn't want to damage the paint on either the car or the hatch.
Install is reverse of removal.
Easy.
Easy.
It's not because of the rear gear. i've seen high rise hatch cars with 2:73's and i've seen low rise hatch cars with 3:23
i once saw a 95 T/A in blue with what looked like every option EXCEPT the hatch. it even had traction control. it was kind of odd to see.
It was just a seperate $375 option (code T43) from 95 to i think 97 and was standard on 98+. for 93 i believe ALL trans am's had it (although i did see one without it but it was a GM test mule car that even had a slightly different dash top) and then in 94 they had the T/A with the low rise spoiler and the T/A GT with the high rise.
FWIW the 96 was available with the low rise spoiler. The WS6 package on the T/A i believe mandated the T43 option as well as 3:23 gears in an auto.
Here, email this seller & see if they have a red one.
http://cgi.ebay.com/ebaymotors/ws/eB...n%3D3%26ps%3D6
Where are ya located?!?
Swapping mine right now need to paint yet but bought one off an 02 ws6 for my 94 formula need to change the latch off of the car because they are different I would for sure have at least 2 people might be able to do it yourself but would be really easy to scratch up your paint.
I think there is only one highrise T/A spoiler, however the firehawk used a couple of different spoilers that bolted onto the T/A highrise hatch.
this one in 2000
and this one in 01-02
i think there were some aftermarket ones too, like one from mecham but as far as SLP/Factory spoilers i think there were only 4 counting the low rise firebird one.
this one in 2000
