Formula with Fog Lights
Hey Guys
Im adding a Trans Am front bumper and fog light rebar. I have the wiring from the car i got the bumper from so im set there. Im just not sure how exactly to wire up the lights if there is the wiring in the harness already and i just have to trace it. I know that the fog light switch is also on the dash just has to be wired in which i also have a dash surrounding with the fog light switch. Im sure alot of people have swapped the Formula front end for the Trans Am just want to see how people have wired up the fogs whether they have to rewire them in or if the wiring is already there i just have to trace it out.
Thanks!
Thanks!
When I wired mine up after swapping to the Trans Am bumper, I followed this guide. Don't know the original author of this write up. Just saved the page before Geocities shut down.
http://www.blindeyed.com/car/saved/foglights.html
Worked like a charm for me
Copy & Paste Moderator
I guess it depends on the year, but 1998-2002 Formulas have fog lights. No need for rewiring. The only thing you may have to do is extend the wires if they don't reach the new fog light locations. Also, if you have a Formula, wouldn't you know if your own car had fog lights?
My car is a 95 formula which technically never came with fog lights from the factory. I'm putting on a trans am front bumper cover with fogs and was inquiring whether or not the harness for the fog lights and switch are there or not.
Thanks
Thanks
