S2000 Engine Start Diagram Problem
I'm following a diagram from this link:
https://ls1tech.com/forums/appearanc...t-mod-how.html
I don't understand the explanation at the beginning of the second page when it says:
"If you want to disable the key start so only the button starts the motor, cut the yellow wire and connect as shown. If you want both to work, only tap the yellow wire as shown by the dashed line."
Anyone?
I also remember there being a write up with pictures but can't find it anymore.
Anyone?
If you do not cut the wire from the ingition switch and just tap the wire into it from the button you can still use the key to start the car if you want. If you dont want the key to start the car then you cut the wire from the ignition switch and run it to the button and do not reconnect it to the ignition switch
