I boke my $%#@*& antenna off need help
I broke my antenna on my 98 formula getting my car washed at the shell gas station , it was free or else i would have never done it , anyways when i get home my antenna is bent and i tried to staigten it but it broke off , is this a cheap fix , what do i need to replace ,everything? Any help will help me tahnks Next time i will wash my own %$*&@! car. <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" />
Administrator
Re: I boke my $%#@*& antenna off need help
Automatic car washes + f-bodies = <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
Need more details...
Is this a power antenna or not? What actually broke, the mast or the base?
Well given his Firebird avatar I will assume its a power antenna.. if so then its about $70 to replace (part through GM parts direct).. you could replace it with a non power setup for ALOT cheaper (like andy offered)
Sorry to hear.. but stay away from the car washes (especially the ones where they touch your car!!!)
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Steve2000SS:
<strong>Well, given his Firebird avatar I will assume its a power antenna.. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Too, bad on the antenna, but an automatic car wash WILL eat a power antenna IF you leave it up. I worked at a soft cloth car wash for a couple of years, and I would say 75% of all cars with power antennas left up, during the wash came out sans antenna - expensive lesson.
Easy to replace, just remove the spare tire (you'll see the mounting bolt near where the spare tire hook goes, unplug antenna lead and power cables, remove bolt and pull antenna straight down, the fender mount is a rubber socket, you'll see when you disassemble. Install in the reverse.
The black antenna part number is 10282646 and the cost is $65.91 plus shipping.
Try here:
GM Parts Direct
Or our GM Parts sponsor SDPC >>>>>>>>>>
Try here:
GM Parts Direct
