Does anyone have a Trans Am Template
Does anyone have a template or something that I can print out and trace. I need a template of the Trans Am emblem on the doors. I want to paint it on my fuel rail covers. I'm too cheap to order decals for them so I want to paint them on if I can.
Also, what should I use to fill the word corvette?
TIA
TIA
Originally Posted by Mustang5.Ohater
I used Bondo's "quick fix" it comes in a can that just "squirts" it out....and I used decals
Just pay the $10-15 for the decals and be done with it. It's going to be a LOT more work tracing and cutting out letters than if you just applied the decals. What are you going to use for a template material and how are you going to seal it down tight enought on the curved face of the FRCs so that the paint does not leak through. Your best bet is to use a paint mask which if you have cut will cost as much or more than just buying the decal.
Good luck.
Bryan
parbreak
Good luck.
Bryan
parbreak
i did a trick on my friends ta, I took a sheet of tracing paper and used the ones on his door and use a 2f pencil, shaved half of it off and schetched away. I then had something to go with. I then made a corrugated template than made a mylar template of this. I can now make designs on FRC or windows or even paint them on the doors themselves.
