Sponsored by: DashLynx
bumper lights
Old 01-16-2003, 12:33 AM
cameroz282k's Avatar
Default bumper lights
is ther any body who can tell me how to get the bumper lights out of the frount of my 00 <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> putting in clears <img border="0" alt="[driving]" title="" src="graemlins/gr_driving3.gif" />
Old 01-16-2003, 11:17 AM
Xsta Z 28's Avatar
Default Re: bumper lights
Take out the headlights and it all becomes very apparent. One 10mm bolt and the headlights slide out.
Old 01-16-2003, 08:29 PM
yah took out the head lights and took the bolts out of the bumper lights but still have no room to get the lights out because of the clearance between the bumper mount L bracket on the fender any other info will be greatly apre.
thanx joel <img border="0" alt="[driving]" title="" src="graemlins/gr_driving3.gif" />
Old 01-17-2003, 01:48 AM
blown 346's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by cameroz282k:
<strong> yah took out the head lights and took the bolts out of the bumper lights but still have no room to get the lights out because of the clearance between the bumper mount L bracket on the fender any other info will be greatly apre.
thanx joel <img border="0" alt="[driving]" title="" src="graemlins/gr_driving3.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">What I had to do which made it asier on me without taking out the headlight assembly is just go from underneath the car. there will be the little plastic doors on both sides of the car take out the bolts and since you already have the bolts out of the parking lights, all you need to do is the tricky part.The lights wont come out easy you might have to work with them and pull one side out first and dont be scared if you have to pull on the front nose a little they will eventually come out. hope this helps.
Old 01-17-2003, 05:21 AM
JLMoses's Avatar
on my camaro I took out the headlight, took out the 5 snap pins across nose of car under hood. Then slide the nose off the lip, and take out screw in the turn signal housing. Then u will have to pull plastic area that's under the light on the nose of car up and slide the lense outta the area it rests in. It's kinda tricky and be careful not to scratch or web the paint. Good Luck
Old 01-17-2003, 02:01 PM
thanx for all the replys might be able to handle it now but is going to be tricky so any more info i will be greatful <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" /> <img border="0" alt="[driving]" title="" src="graemlins/gr_driving3.gif" />
thanx again
JOEL PATE
Old 01-17-2003, 02:09 PM
ratio411's Avatar
It's super easy...
Take out the single 10mm bolt on the back of each headlight housing.
Unplug bulbs.
Slide housing towards nose of car.
Pull headlight housing from car.
The corner lamps are then right there in your face while you are on your feet. There were no other obsticles for me when I put the clears in.
I started doing it from the bottom, but that was terrible. I have hands the size of hams, so it wasn't going to happen from the bottom.
With the lights out you have gobs of room and no crap falling in your eyeballs.
Good luck
Dave
Old 01-17-2003, 02:26 PM
Xsta Z 28's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by DARK AGE 53:
<strong>If you're just looking on how to remove the headlight assembly this post might help https://ls1tech.com/ubb/ultimatebb.p...=002164#000003 , I find it much easier to pull out the fascia when removing the headlights. I hope this helps some but if not I'm sure someone will come along with the right answer, good luck.
Al</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Great write up Al,
Here it is in full:
Here's how I've done them in the past.
1. Remove the five black push-in pins from the top of the fasica. This will allow you to pull the fascia out while sliding the headlight assembly towards the center of the car. By pulling out the fascia it will give you that needed extra room to pull the headlight out, I remove the headlight at a slight angle.
<img src="http://groups.msn.com/_Secure/0MgCdFFkRxaXjd8RfLVcO6w!Qee02lhdzGQjyMH2RW6Ihj083l x9EiRyFt33vSyFHA1ZUz7tqV5dxbmFfwXOAdg/C5.jpg" alt=" - " />
2. Remove the 10mm bolt from the back of the headlight, no other bolt should be removed to take the headlight assembly out.
<img src="http://groups.msn.com/_Secure/0MgB0cFcRZ6V5fuxtaNMIu04SNU9eLxrN4B2wtdW41uz0kYZOZ 06dq4NObgIRjLx1k2HDLBy1ybjRVl962oa3SQ/C3.jpg" alt=" - " />
3. I like to use masking or duct tape EXCELLENT ADVICE!!! on the fascia around the headlight area, this will help protect the paint on the fasia. Looking at the back of the headlight you'll notice two tabs, when re-installing the headlight make sure you slide the two tabs in the proper area. The blue tape shows the tabs.
<img src="http://groups.msn.com/_Secure/0MgAAAFgRlqXKw*BI*WuVNI6CHFLHWhkq0q7joVWifqKrspVZq hUAn7nVu7rnlHOAIi*TTMhjXEdZkJ4OIDCo8Q/C4.jpg" alt=" - " />
One thing I forgot to mention is you need to disconnect or remove the headlight bulbs before you pull the headlight assembly out, if you remove the bulbs do not touch the bulb with your fingers.
Thanks again AL!!!!!
Old 01-17-2003, 02:49 PM
HEY GREAT GOT THAT FAR CAN YOU DO THE SAME FOR THE BUMPER LIGHTS YOU KNOW GIVE PICS FOR THE STEPS THANX <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
