Prostars wont fit...
Re: Prostars wont fit...
An Air Grinder is your friend.
Get one or get someone who has one to help you out.
Put the rim on the car with the lugs finger tight and see there they hit. GRIND. Put the rims on a little tighter and see where they hit. GRIND.
You should spin the rim to see where it is hitting. Do this as you get closer to having everything clear. You could also use a black marker on the claibers so the scratched-silver areas will reveal the areas needing grinding.
