How to take off fuel door???
Re: How to take off fuel door???
I know this has been discussed before, and is on my list of mods to do for sure. Try doing a search to see what comes up.
What are you replacing yours with?
http://www.bfranker.badz28.com/fbody/Guides.htm
then go down to other under "Aluminum fuel door"
it has a full install with pics. Looks like a cool mod, let me know how it goes if you do it.
<small>[ February 18, 2003, 08:55 PM: Message edited by: NightHawk ]</small>
Real simple. When you open the door, you will see 2 rivets that attach the hinge to the body, drill those rivets off, fuel door comes off. Use a bit just big enough to get the rivets out. You will be able to easily re-attach the door on down the Rd if you want. Good luck.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Black Sunshine/ 00SS:
<strong> Real simple. When you open the door, you will see 2 rivets that attach the hinge to the body, drill those rivets off, fuel door comes off. Use a bit just big enough to get the rivets out. You will be able to easily re-attach the door on down the Rd if you want. Good luck. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">yep....what he said.... <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
its really an easy project.....just takes a little grinding here and there. I'm happy with how it came out. Post pics when you get finished. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
