Sponsored by: DashLynx
How to remove the dash 99?
Old 04-03-2011, 09:54 AM
GOR1LA's Avatar
Default How to remove the dash 99?
Curious how hard is it to remove the dash from a 99 TA and what needs to be done to remove it?
Thanks
Old 04-03-2011, 01:02 PM
rbaksi's Avatar
This has been posted a few times. Just remove the A-pillars using the screws at the t-tops, then remove the upper dash pad by prying up at the corners towards the middle. Then there's like 5or6 screws holding it in at the top. Also remove te glovebox and the kneeplate under the steering wheel and there's a few screws there. It'll the. Just pull out after you disconnect the hvac controls and the radio
Quick Reply: How to remove the dash 99?
