Started interior mods (LED's)
So I put in my new bulbs from superbrightleds.com and they look great. I just need to finish by converting the steering wheel buttons, traction control/fog light switches and eventually a new headunit, in green of course Anyways here's a pic of the progress so far.
and the car we're dealing with-
Comments and suggestions welcome
Regards,
Ryan
Regards,
Ryan
I don't know yet lol but I do know that it's possible.
EDIT: Fellow forum member helped me out alot, here's a link with a how to
http://www.keliente.com/switches.htm
^^Thanks, I think the yellow would look awesome and I always had the idea of getting a McNord overlay and having the black face gauges, like stock, but the having the tach yellow- a la Ferrari. I think that would look sick on a car like yours Pete.
Thanks guys. I'm dying to finish the rest but I've been slammed at work and I've had alot of design projects as well. I should be able to get to it in a couple weeks
It's not to hard to change them. You just need to pop the covers off and remove the circuit board from the back of them. Of course this is all off from the car. I tried a set with 3MM LEDs and a resistor. You could probably get a 5MM in there. I can't recall how mcuh space there is between the two bulbs.
I used this list to order the right bulbs https://ls1tech.com/forums/appearanc...-led-list.html
And then I read this thread for a quick how to. It's pretty easy to figure out though https://ls1tech.com/forums/appearanc...eds-guide.html
^ the bulbs on the list and the ones I used aren't standard leds. they're the SMD ones that look like a little micro chip. Wicked brite though and they are small enough that there's multiple leds, aimed in different directions, on the same bulb.
