Air/fuel gauge hot wire
What wire do you tie into on the Oxygen sensor when running the hot wire from the a/f gauge?
Also, I don't believe that I have to buy anything additional to get it workin.. Pacesetter headers with o2 sensors and autometer a/f gauge. Sound about right??
uhh are you trying to tie an A/F gauge into a narrowband (stock) o2 sensor? Not going to work how you want it to. You need an actual wideband controller with o2 sensor that you drill and weld another bung to the headers behind the existing narrowband o2s to get your readings
