Sponsored by: DashLynx
Need help asap
Old 08-30-2012, 03:21 PM
wavebyby's Avatar
Default Need help asap
Im buying these cheap gauges from glow shift because i dont have the money to spend on the good ones right now and I like the look of the triple pod with gauges in it , any way Im buying this water temp gauge and the sending unit that goes in the water hose line comes in different sizes does any one know what size i need
I have a 2000 camaro ss
the sizes are 28mm-30mm-32mm-34mm-36mm-38mm-40mm and 42mm
Old 08-30-2012, 03:22 PM
wavebyby's Avatar
http://www.glowshiftdirect.com/Water-Hose-Adapters.aspx
Old 09-03-2012, 04:24 PM
YURVIEW's Avatar
i believe upper hose is 1 1/4"..... but I'm sure Glowshift can tell you the correct part. They've been very knowledgeble in my dealings with them.
Old 09-03-2012, 06:52 PM
wavebyby's Avatar
got them on the phone and they had all the sizes i needed , thanks for the help cant wait for them to get here so i can hook them up . They are nothing great but right now it was all i can afford so they will work for now
Old 09-03-2012, 06:59 PM
YURVIEW's Avatar
Good gauges. They work well. Ive had their fuel pressure gauge for some time now. It was real picky about where u grounded it, but once found good spot, its been fine. Just installed their oil pressure, oil temp, and boost gauges, but car isn't running yet, so can't test to them.
Quick Reply: Need help asap
