Clear Turn signals and marker are here, quick question
I just got my clear turn signal and marker light housings. I want to make sure they are sealed up nicely. Clear RTV around the perimeter of the lens? Anywhere else?
Which color bulb should i put in the rear side marker lights? There is a silver tinted clear bulb in right now, but the housings came with a set of red bulbs and a set of orange bulbs.
Trunion King
Before you put it on the car, this is what I would do... I would test fit it first and look for any crack between the light housing and the socket, do a light spray of water to see any water leaks. I found out on mine that is where the leaks are coming from. The rubber seal doesn't seal it all the way so I placed copper coat at the rubber seal to help it to seal better.
