Sponsored by: DashLynx
How to change headlights
Old 01-11-2013, 05:16 PM
01WS6STANBO's Avatar
Default How to change headlights
I got an 01 trans am and I'm trying to change the headlights to hid lights but I don't what I need to do. So let me know what I need or recommendations.
Old 01-11-2013, 05:24 PM
babbage1109's Avatar
Search. In the electronics section.
Old 01-12-2013, 12:02 PM
Blackpanther99's Avatar
You have to do a conversion by replacing the current headlights lamps. Try this following write up from a member here in LS1 tech It helped me out alot!
https://ls1tech.com/forums/appearanc...-trans-am.html
Old 01-14-2013, 05:50 AM
Sail Hatan's Avatar
Either you have to drill out your stock housings and glue in an hid bulb, which has shitty output (i tried that first) or you have to buy euro housings and then put Hids in those, which is what I did after realizing that option one sucked. cost less than 100 bucks, and no I can see at light. its all plug and play.
Old 01-14-2013, 12:37 PM
Copy & Paste Moderator
VIP1's Avatar
Check out the Lighting FAQ.
https://ls1tech.com/forums/appearanc...hting-faq.html
There are basically 2 paths with branching options:
1.) (BAD) Halogen Reflector Housings with a HID kit
2.) (GOOD) Projectors with an HID kit.
There is more details and information about both in the Lighting FAQ.
There is also a sponsor that sells a Projector Kit, or you can assemble your own.
Quick Reply: How to change headlights
