The New HID/LMC Housing Write-up **Updated**
The following users liked this post:
k3000 (06-08-2021)
Did some research and found Hella 60mm's for $80 a pair, grabbed an HID kit for $40 shipped with a relay harness, and decided against fabbing my own adapter plates and just bought Tram's plates from eBay for $60, all together cost me about $180 shipped to my door. $80 extra to do it right the first time, I call that a win, thanks lemons!
And for anyone wondering, it wouldn't be hard to make your own adapter plates... Anyone with a little measuring and a few tools should be able to complete that for under 10$ and an hours worth of work, so you would have 120$ in the entire thing.
I did sense a small amount of sarcasm... But I hope you don't think that way in the least little bit.
blsnelling (04-09-2020)
Stupid question, but how do you pop off those 3 plastic pins on the bottom of the bumper?
Thanks for the write up! This is now on the list of things to do!
For the lt1s
You mentioned just needing the low beams. For the 93-97 ta's is the correct housings from lmc the 36-0302?
Is that what you would recommend? Or what housing would you recommend if I got the bulbs that have both hi and low beam? Thanks for your help.
Take some pics of your setup. I'd like to see the finished product.
#32
I don't mean to hijack this thread AT ALL! Just replying to Tram
I ended up not getting the adapter plates... my dad was going to buy them but had some stuff come up and didn't have the cash. I already had all the other parts, so I decided to fab something up for now until I buy the plates and do it right.
I used some ABS plastic plates cut to fit the metal trim ring of the stock halogens to hold the Hella projectors in place. I used a hole saw to cut a larger hole in the stock light bucket to fit the projector housing, and then sandwiched it all together with the metal trim ring. It holds everything tight, but it's not as solid as I'd like, so I'm definitely still going to be buying the plates. Mounting these things CAN be done for free, but it's not as nice as Tram's plates. Still works for now
#36
Damn, this car must have some COOOOOOOLD A/C
Just did my car this weekend. Both of the 5 pin connectors were shot so I replaced them with Weatherpaks. Left the bulbs that came with the housings in there for now. I will change them out later when I have a few less other things to be doing. lol
I did purchase the woring harness though. I basically used it for the plus and the extra wire. I was able to cut the wires long, add the Weatherpak pins and plug them in.
Now I have to do my other Trans Am.......
#39
I installed the LMC housings with a Morimoto 9006 kit. Originally after installing they were pointed pretty much straight in front of the car. Re-aimed and still need to tweak them since I'm getting flashed, but they definitely look cool.
One problem I did have was the wire that comes out of the driver's side HID capsule would touch the shroud and ground out. Ended up having to tweak it for it to sit right. Not sure if the culprit was bulb or housing, but will test with another set of bulbs to see.
Can someone please post some pictures of the output against a wall?? The beam pattern on them is extremely scattered and I'd like to see if possibly I just got a bad set of housings. At this point the Eurolamps and Bosch housings I had on my old Firehawk were way more focused than the LMCs. I'll snap a picture this evening of how mine look.
#40
It is the incorrect way to do a mod.
Never understood the "I don't like the way projectors look". Literally the only time you see them is a NIGHT time with the head lights up and the head lights on. And its hard to tell what you're looking at then.
