Gauges Help
Old 02-05-2013, 12:29 PM
Austin1249's Avatar
Default Gauges Help
Hey I took my instrument panel out to replace the bulbs with red leds. I never turned the key over to get all gauges to zero. I just took it out where they were when i shut the car off. My question is how do i get my gauges back to an accurate reading do I just set them where they were or turn them to zero (minus the fuel gauge) thanks.
Old 02-05-2013, 12:33 PM
Atrus_SS's Avatar
Did you pull the needles off? As long as you didn't pull the needles off, you should be just fine. Everything will reset to it's proper reading.
Old 02-05-2013, 01:35 PM
Austin1249's Avatar
I never pulled the neddles but my voltage, oil press. temp, and gas all have moved do i just move them back to their location before removing i took a picture of them. or just leave them alone and they reset?? Thanks for replie
Old 02-05-2013, 02:31 PM
Atrus_SS's Avatar
I'd leave them alone. I am 99.9% sure they will "reset" appropriately when you first fire the car back up. I can say with 100% certainly they they will be jacked up if you try to adjust the needles now.
Quick Reply: Gauges Help
