In the middle of cutting down A4 shift lever, and need advice
The groove on the front and back of the shifter tube... What did you guys use to cut it? I've been using a cutting disc on the front one (which has been a PITA), and while it works, it leaves the bottom part rounded instead of squared off as I would like it. What did you guys use to cut those?
