Headlight kits for Trans Am
BLS, only way to go for good lighting, but if you can't afford that and drive a 98+ T/A then you could get a set of the LMC truck headlights (like what go on a 90 silverado, before they went to the one piece headlight and had 2 separate units on each side), this will be a step up in lighting but nothing like what you see with the BLS kit.
Let us know if you have any questions. We can offer complete kits or a custom build if you don't need some of the HID components. We are planning to offer a more basic setup later this month as well for those who simply want performance and aren't too concerned with aesthetics.
We could probably put something together but would need to see a set in hand. From what I know, the square housing is the low beam and the projector is the high. Ideal solution would be to replace the projector with a proper low beam or bixenon unit and drop in a new square housing as an additional high beam. I've never seen one up close so this is all speculation on my part.
The 98 and up has a 16volt battery and charging system, will that be a problem?
