I had an oil leak, so I decided to take my whole car apart.
Thisis by far the best "how-to" for fixing an oil pan leak! Well done,awesome documentation, and I love how it just kept spiraling out of control. Itmay have been covered, but is there anything you would have done differently inanother go around?
Also, I can agree with the Blackheart sentiments, it sounds so good! The onlything I regret is that it's not 3". I know what they were going for, and myground clearance is awesome with the Blackheart. But why, oh why wouldn't youdo a 3"? It nags at me in the back of my mind every time I go WOT...
PsychoSid, are you paying attention?
Uhmmm,what are you trying to get at there buddy? That I'm taking to long? That I'mnot OCD enough? (we know that's not true). What?! Huh? What?! Get off my back!I'm doing the best I can!!!
Great great work man ! I can't wait to start addressing my engine bay, hopefully I will get the opportunity to when I do this next motor swap. Just having a dry engine is so pleasant when you are underneath it
A boat load of Simple Green and Gunk Engine Degreaser. I used the blue scratchless Scotch Brite pads. For the heads and deck, I used Permatex Gasket Remover.
It's nice not having to dawn a hazmat suit when doing simple work to the car now.
I dug around and found a few more pics people might find humorous.
What do you do when it's 100* outside but you really want to bust out the microfiber and clay bar your fenders? This is where having an understanding wife pays dividends.
Considering the condition of everything in the engine bay, I was shocked to find my knock sensors were in perfect condition.
If you were wondering how I supported the motor when I reinstalled the covers, here you go!
I replaced the oil barbell while I was in there and polished the part of the crank that rides the rear cover seal with some fine emery cloth to remove the groove that develops over time. I was super ocd about every surface a seal went being 100% clean and defect free. I didn't want to have to redo anything, especially once it was back in the car. It's also satisfying knowing that literally every bolt on the car has been hand torqued. That might have been excessive, but I was more than done with finding loose stuff.
Don't tell your friends that you did this to fix an oil leak, they will wait until your car is alone and pour some oil on the ground beneath it. Nice car and story though.
I can't wait to see your next project entitled "I heard a rattle inside the car, now check out my custom interior". Who says OCD is a bad thing. So are you going to be selling a modified car anytime soon cause I wouldn't hesitate to buy if it came from your garage. Great job and great write up.
#33
this is an awesome build!! props to you for your determination to get it done! I was curious, what size bolts did you order from bolt depot to replace things in the engine bay from the old rusty ones? also, did you get chrome ones, or do they even offer those?
#35
https://www.boltdepot.com/fastener-i...read-Sizes.pdf
And compared each bolt to it to find the thread pitch and then used a ruler to determine the diameter and length. I then picked washers that had listed diameters that were close to what I was replacing. I will warn that the larger washers, such as the the ones securing the fenders and airbox, were a bit thinner than I had preferred. They did concave a little once tightened.
I attached two screenshots of each of my orders for the bolts I used in and under my engine bay. This covered almost everything except my throttle body, intake, and engine covers. I used zinc bolts for the things I felt needed to be more strong and secure such as the hood latch and hinges. Please use this as just an example and not a shopping list.
#37
As for selling it, nah, not anytime soon. I've driven it a few times now with everything lined out and am having entirely too much fun with it.
#38
