Finally got cme installed
I think it looks great. Can you provide any tips on installing the valence? I have an OEM valence however I am unsure how to install it correctly. Is it just 3m body tape or do you add screws as well? Thanks.
Sorry it took so long to reply, been busy lately. It was a little tricky getting it lined up, but not too bad. It is 3m tape all the way around, as well as 3 plastic push pins. There is a push pin on each side right behind the tire, and one in the middle above the cme. It's still very secure, and is not going anywhere. I had someone help me hold it in place, while I put pieces of painters tape all the way around to hold it in place. Once it was in place, I slowly pealed the 3m tape while pressing it on the bumper as I went. Pretty straight forward.
I'll snap a few pictures of the rear section. The only thing I did was undue the clamps holding the tips on, and remove them. Then I took the car to an exhaust shop, and they welded on two 90 degree elbows to the existing borla pipes. They also added two extra hangers at the elbows for stability.
Got the same CME on the Kooks true dual setup. Excellent product!
