When FLITZ & Mothers Billet dont work?
I have a set of Boyd Smoothie II's that have some nasty discoloration and what looks like rainbow colored oil stains in the aluminum. I have the ZOOPS kit sitting in my garage also picked up some Buffs from Eastwoods and I have been polishing my but off but the stains wont come out.
What should I use when Mothers Billet and Flitz dont cut it?
rolite works well & so does wenol those should work wirh the polishing heads form eastwood. make sure you clean them with a non acid wheel cleaner like automagic's MAGnificent. the discoloration seems as though it may be where someone had cleaned them and the solution wasnt cleaned off properly. so clean them very well with out using anything with acid cause it will remove the clear then polish away.
