Sponsored by: DashLynx
TA Sideskirt question???
Old 07-31-2004, 09:39 PM
dan102877's Avatar
Question TA Sideskirt question???
I just recently purchased an '00 TA, and I noticed on the passenger side, my sideskirt was a little loose in the front. I looked a little closer, and realized the large black, plastic looking screw that holds it in place is missing. Does anyone know where i could find a replacement for this? I'm not really too familiar with the various sites out there yet to look. Thanks.
Old 08-02-2004, 12:01 AM
WSSix's Avatar
Lowe's carries them around here, as does AutoZone. There is one you can see just staring at the wheel well. And if you look underneath the car, there are two more in the front (different size) that push up perpendicular to the ground into the fender.
If it is really loose, the plastic push rivets might not fix the problem entirely. There are two nuts on the inside of the front fender that hold the skirt on and they are the cheap stamped steel kind that can come loose. To get at them you need to go in behind the wheel liner.
Have fun!
