Arrowhead emblem on TA
I had the same idea. The only thing is that the GTO arrowhead has 2 0r three tabs that stick out of the back of the arrowhead. You have to get a arrowhead and then ground down the tabs so it will set flush on the car. The GTO's have pre drilled holes in the trunk for this reason. I am still going to install one on mine when I get done with the body work. May take a while. O and I was trying to use the one off the rear bumper. It is smaller and fits the area on the front of the Trans am better.
Haven't heard of anyone doing a GTO pontiac arrowhead on the T/A, but I have seen them with the Pontiac arrow on the front of the nose right under the nostrils. It's the same arrow they put on the Sunfire. I've seen them somewhere on-line, but a dealer should have them.
Last of the breed badges--http://www.mdgglobal.com/USSpecialEd/PONTIAC/LOB/LOB.htm
werd I checked into that when the GTO's first came out and found the samething. I also found that the arrowhead on the bumper is curved and it wouldn't fit flush. I wanted the one on the truck because it wasn't as big. Im still getting one too and Ill just make it work.
Originally Posted by 01 Red WS6
that looks really good. For the front bumper did you use the front bumper emblem on the GTO? I was worried about it being too big but it fit really well there.
GTO emblem
It is an emblem from a GTO front bumper, it's the same size as the old Grand Am emblem I had on there, about 3 inches. These are not Photo-chops, the CETA-bumper pic is, but the others are not. I'm a freelance illustrator and i've been using Photoshop for at least 10 years. It's the only program I use for my work. I took the pictures with a digital camera and cropped them with Photoshop, hence the .psd in the filename. I'm contemplating whether or not to do the CETA bumper, that's the reason for that pic.
Man that looks real good in my opinion. I was thinkink of going with a carbon fiber one I found on ebay for a sunfire seems to be the same size. Do you live in NC
