Sponsored by: DashLynx
Gauge overlay install
Old 12-29-2004, 12:50 PM
pailheadz28's Avatar
Default Gauge overlay install
Does anyone know where there is a good howto on installing whiteface gauges? Got one for christmas from the wife for my Z.. just need to find a how-to on installing it..
Old 12-29-2004, 08:32 PM
ddelallata's Avatar
what brand are the overlays? MacEwen or NR Auto? The MacEwens just go on top of the stockers and the NR Auto overlays require a little more work.... you have to remove the needles and put them back in the exact same position. It helps if you make a diagram of where the needles rest with the ignition key turned to the ON position. Then when you're ready to put the needles back on turn the ignition switch to the ON position and gently put them back on without pushing them in all the way.
Old 12-29-2004, 08:48 PM
01pewter2001z28's Avatar
If you got replacement gauges here is the install we did on my WCA Scott Settlemire signature gauges. http://www.01pewterz28.cz28.com/wcagauges.htm
Sean
