Where can I get these plastic located behind the
Where can I get these plastic located behind the door panels? What are they called? I checked mine and it looks like the previous owner cut a big hole in it. Thanks!
The only place i can think of is the dealership.Another thing you could do even though its pricey,is use some dynamat sound deadner.It'll work i think for moisture(not sure!),but it'll really kill road noise.
They are just clear plastic to prevent water from contacting the door panel. On a 4th gen f-body you can remove them. Just clean up the icky black adhesive.
On a truck, like in the pic, I don't know if it would be OK to leave it off. You can use any kind of plastic. Duct tape works well in holding it in place.
