Sponsored by: DashLynx
Door Hinge Spot welds broke
Old 12-03-2005, 10:41 AM
mikesz28rocks's Avatar
Default Door Hinge Spot welds broke
I have a 2000 F-Body and the other day my upper and lower hinges broke off i guess i should say. Now is this something i could fix with or by safety requirements would it have to be done at a body shop?
Old 12-03-2005, 11:02 AM
jimbonzzz's Avatar
If you're not confident about doing it yourself, then take it to a shop, I doubt it would cost too much to have them do it.
Old 12-03-2005, 11:14 AM
LT4vert's Avatar
They broke off the body ?!?!
The driver door in my Trans Am cracked at the point where the door hinges are , only way there is , imo , replace the door shells . If the hinges broke off the body you can weld them back on , should be easy to line them back up from the marks left .
Quick Reply: Door Hinge Spot welds broke
