Sponsored by: DashLynx
CAMARO insert application advice?
Old 01-12-2006, 03:20 PM
USMARINE1108's Avatar
Default CAMARO insert application advice?
I put front and rear inserts (fill in's) on my car and messed them up. They look like crap. So, I ordered new ones and am ready to put them on. How did you do it? Did you use soap? Any help is appreciated. Thanks.
Old 01-12-2006, 03:24 PM
StripedZebra's Avatar
http://www.bfranker.badz28.com/vinyl/vinylinstall1.htm
Thats how i did mine....
Old 01-12-2006, 03:45 PM
Renegade's Avatar
I cleaned the surface off really well, with alcohol. Then put the vinyls on very careful, blow drying each one for a couple of minutes until they were on good. I've had them on for about 6 months and they still look great :-). Good luck, just read some advice, and try try again.
Old 01-12-2006, 03:47 PM
Lordsauran's Avatar
i just used soapy water in a spray bottle and put them on and lightly tapped it with a towel to dry it a little
Old 01-12-2006, 03:58 PM
Zymosis's Avatar
Originally Posted by StripedZebra
Exactly how I did mine. Worked good for a year. The corners on 2 of them are starting to peal a bit. But its not noticable until you are close. As far as instructions, those are what I'd follow.
Old 01-15-2006, 09:46 PM
Thanks guys.
