Sponsored by: DashLynx
Headlight question
Old 02-12-2006, 11:42 AM
ATCFLYBOY02's Avatar
Default Headlight question
How do you get the plastic lens off of the headlight? I am doin some mods and I just need ot get this lens off. Any help???
DR
Old 02-12-2006, 12:39 PM
Danny2tek's Avatar
I believe you have to bake them. Search for whistler mod.
Old 02-12-2006, 02:17 PM
Zeus's Avatar
Remove the 4 metal clips from each headlight and then place them in the oven at 200degrees for 20min. Take a butter knife and run it down the seam between the lens and the housing. Pry slightly, but be careful as the plastics are brittle and will break. If it's not coming off, put in the over another 5min.
That's the method I used when I did the Whistler mod and it worked well enough.
Old 02-12-2006, 03:32 PM
SmokeySS's Avatar
^^^ What they said about the oven. Here's a more detailed how-to as found in the sticky "Appearance Hall of Fame" at the top of this folder.
http://www.cardomain.com/ride/224386/2
Old 02-12-2006, 03:50 PM
you guys r awesome!!!! thanks alot!
DR
Old 02-13-2006, 10:15 AM
ok I DID THE WHISPER mod and it look awesome... Thanks alot guys.. Ill post up some pics later.
DR
