Sponsored by: DashLynx
VHT Nightshade - does it contain clearcoat?
Old 04-12-2006, 12:12 PM
BlackHawk T/A's Avatar
Default VHT Nightshade - does it contain clearcoat?
Or do you need to clear over them when you are done?
Old 04-12-2006, 01:45 PM
1SicV8's Avatar
im pretty sure it doesn't, ive cleared over mine and i havent. and both have held up well
Old 04-12-2006, 02:10 PM
daryl2cb@yahoo.com's Avatar
I cleared over mine as well
Old 04-12-2006, 02:13 PM
Moderator
nhra-trans-am's Avatar
Old 04-12-2006, 07:30 PM
ArcticZ28's Avatar
you'll want to clear them if you don't want them to fade. And if you want them to not have a grainy finish from the clear, you'll have to wet-sand and then polish them up with an orbital or some elbow grease.
Old 04-12-2006, 07:34 PM
Tech's Avatar
Definitely clear over them.
Old 04-12-2006, 07:59 PM
blackbird00's Avatar
yes clear them i ended up sanding all of it off and had them professionally painted. So much more happier but what do you expect from a 10$ can of paint.
Old 04-12-2006, 10:28 PM
LS144's Avatar
what kinda clear u all use? I got some clear coat left over from painting my dads truck should I put it in the gun and give it a quick spray?
Old 04-12-2006, 10:30 PM
ArcticZ28's Avatar
Sure, any clear should work. Maybe about two decent coats, nothing extreme. I just used the spray can clear.
Old 04-13-2006, 01:20 AM
So how much clear do you need to ensure you won't sand it all off?
These will be just the side markers, so they are small and flat and easy to work on unlike tail lights.
Old 04-13-2006, 10:33 AM
ArcticZ28's Avatar
Two good coats should be fine.
Quick Reply: VHT Nightshade - does it contain clearcoat?
