L.E.D. clear corner question
the one you will find at pep boys and auto zone are pretty crappy. use these
http://stores.ebay.com/Velocity-LEDs...QQftidZ2QQtZkm
and here is the flasher you will need
http://cgi.ebay.com/ebaymotors/led-t...5920QQtcZphoto
Yeah, I would love to switch to LEDs because the bulbs i use always melt the clear corner housings. But the primary reason I havent switched to LEDs yet is because Ive always heard they arent bright enough.
My buddy has LEDs, and I haven't seen his car since he did his fronts, but I did see the back, and they are very dim. I was able to see them, but they didn't light up that bright at all. I wouldn't like them.
I have leds in my side markers, mirror and dome lights, and the lisence plate light. I got the interior leds from http://www.ledgauges.com and the others at www.superbrightleds.com. For all the exterior leds, I used WLED-x5 LED Wedge Base Bulbs from http://www.superbrightleds.com/mini-wedge.html
They are very close to the same brightness as the stock lights, but I'm still using the stock corners, not sure how it would look with clear ones.
