Sponsored by: DashLynx
Need help with headlight conversion 95 firebird
Old 09-02-2006, 08:28 PM
FirebirdStud's Avatar
Exclamation Need help with headlight conversion 95 firebird
Well, I bought the glass housings off ebay like two years ago, that fit in a 95 bird but use h-4 bulbs. Anyway, I cant see crap with them. Im getting sick of them. All I can think of is it isn't reflecting enough or something. I am using blue bulbs too. On high beams, my car is still dimmer than the low beams of most vehicles I pass.
So, what other options are there? I am sick of not being able to see, but I dont want the crappy yellow stock ones either.
So, what have you done, has it worked, likes dislikes??
Thanks!
Cody
Old 09-02-2006, 08:40 PM
LS1_SS's Avatar
We have HID kits for your car. PM me if you are interested!
-Nathan
Old 09-02-2006, 10:10 PM
Blackbirdws6's Avatar
There are options including a better housing than the ebay one you bought as well as HID kits as mentioned above. PM if you want more specific info.
-Brian
Old 09-03-2006, 11:57 AM
I would love to have HID, but cant afford that right now. I would like some options right now. Thanks all!
Old 09-04-2006, 02:24 PM
Copy & Paste Moderator
VIP1's Avatar
Cheaper solution than HID...
Better housings and clear bulbs (GE Nighthawks, Phillips XtraVision, or Sylvania XtraVision -- in order of preference)
You can probably make your own housings similar to the way housings for the 1998-2002 can be made (which I have done).
https://ls1tech.com/forums/appearance-detailing/566308-clear-head-lamps-trans-am.html
Lumens output
(from Sylvania's site, for their standard bulbs):
(Bulb: low/high)
9003/H4: 910/1500
9007: 1000/1350
H13: 1000/1500
Maybe you can try to rig up something that uses the H13 since it has a higher lumens output (which might be hard to do and hard to find).
Some people have also used the RallyLights "freeform" housings and Hella premium lamps (some have said 100watts, but that sounds a bit high). Blackbirdws6 has that setup.
Old 09-12-2006, 09:42 PM
VIP1's Avatar
Any update?
Quick Reply: Need help with headlight conversion 95 firebird
