Shift light locations
Just picked up a shiftlight and i'm wanting to get some ideas on placement, i'm thinking a pillar or on the dash to the right of the steering wheel, toss me some ideas lil buddies.
I put my Raptor inside my TA's center AC vent. Very stealth, and I see it just fine. I had to fabricate a small base, so that thelight was angles correctly, no big deal tho.
Mine is in the same spot as blacknred's, except blue Works like a charm, and nobody sees that ****.... Its also a harlan. i just velcro'ed it to the floor of the vent. job complete......
Look above the odometer. Eventually I'm going to get a new bezel and do a cleaner install.
http://www.carstereo.com/installs/ph...w=1&maxrows=12
was goint to put mine (raptor) in the pillar vent but wanted to be able to put the cover on and off easily. Put mine right in front of the shifter in the little pocket you don't even notice it until you look for it
Originally Posted by 99blancoSS
Put it where you can easily see it while your staring down the track. It wont do any good if you have to look for it. It should be where when it lights you see it while your staring straight ahead. I've got a mini light mounted to my tac on the steering column.
Jon
