Sponsored by: DashLynx
93 to 02
Old 10-19-2006, 04:52 AM
Kanes2413's Avatar
Default 93 to 02
I could use some help i couldnt find a how to and whats needed for a lt1 to ls1 front end trans am conversion? can someone show me the way or help out a bit thanks
Old 10-19-2006, 05:57 AM
transambandit's Avatar
https://ls1tech.com/forums/appearance-detailing/568424-my-ws6-progress-so-far.html
f you go here, http://www.trademotion.com/partloca...t=7&catalogid=2 (13, 15, 7, 8, 17, for 8 and 17 if you click on them you can get both the right and left side and you will need both) you can order the brackets/foam and support brace you need, you might be able to find it on ebay. Call around to some of your local salvage yards. If you do a google search for salvage yards you can imput what you need. I did that and i got a call and was given a cheap quote for a bumper and drivers side fender. the ws6 hood i got off an ls2 member which i picked up. I also picked up the headlights from someone on here. The hardest part is getting everything to line up correctly, im still working on getting the ws6 hood to fit. I paid about 1400 for everything and got about 900 back for the stuff i sold. Id try salvage yards then try ebay.
Old 10-24-2006, 01:09 AM
Kanes2413's Avatar
where do i go to get these parts or do i have to get them from a totalled or junkyard car since that trademotion site isnt working
Old 10-24-2006, 01:52 AM
http://www.trademotion.com/partlocat...=7&catalogid=2
try that, see if it works. a junkyard would work out well, otherwise try ebay.
