Sponsored by: DashLynx
help getting weather stripping and clear turn signal housing
Old 01-04-2007, 09:52 PM
LastBlack02SS's Avatar
Default help getting weather stripping and clear turn signal housing
Need some help. I got a set of clear turn signal housings from a friend and one is cracked and taking on water. The bulb popped now too. I need to buy a new one. Any help on where to get it or a part #? It is the passenger side.
I also need to order new weather stripping for the car. I for sure need the ones for the doors on both sides, but if it is only sold in a set of more i might be ok. Any help on part #'S and where to get would be great. The stealership wanted 155 for one door and 255 for the other.
On a last note, when i unlock the trunk, it doesn't release completely - i need to pull up on the trunk while unlocking it. Any help on the situation would be great.
Old 01-09-2007, 12:58 PM
ttttttt. anyone?
Old 01-10-2007, 12:21 AM
any help appreciated
Old 01-10-2007, 01:09 AM
Magnet's Avatar
i would recommend just getting new clear corners off of ebay, they are pretty cheap and you are going to have a hard time finding one to match yours.
hatch release fix:HERE
look down in the miscellaneous section...
I'm not sure on weather stripping, you might want to check your local chevy dealer or gmpartsdirect...
