Anybody know the thickness needed for double sided sticky tape, for CME Rear Valance?
I have a CME rear valance that I need to install in the coming weeks and I received no attaching stuff with it. The 3 little plastic plugs won't be a big issue to locate, but I am real curious as to how thick the double sided sticky foam tape stuff needs to be. I want this nice and tight up to the bumper cover so I can't run to thick and if to thin it won't make contact.
Anybody with CME knowledge know????
Really appreciate any help............
Steve, toofazt, just mounted his with some doublesided 3M tape from AutoZone...
https://ls1tech.com/forums/appearance-detailing/636037-put-cme-56k-warning.html
I actually went to the Chevrolet dealership and bought soe double sided tape use to put body molding on. Just make sure you clean all surfaces touching the tape with alcohol. I would also recommend using a couple small screws to hold everything in place as well, it may sag a bit if not.
