Sponsored by: DashLynx
how to clean/repair swirl marks on tail lights?
Old 04-07-2007, 08:35 PM
vipert/a's Avatar
Default how to clean/repair swirl marks on tail lights?
hey i was just wondering: how to clean the tail lights? mine is all swirl marked up, streaked up and kind of dull looking... how do i get her to shine like new and be flawless? thanks!!
Old 04-08-2007, 12:11 AM
kevinclark09's Avatar
buff them if you have a buffer, but if not some plastix or w.e its called works too. it would take a bit more elbow grease but it eventually gets the job done, i used it on my rear filler panel.
Old 04-08-2007, 02:45 AM
Tim Noel's Avatar
I have used 2000 grit paper, and then buffed them out with compound, followed by polish and a wax. Makes them look really sharp, and it does remove the scratches.
Old 04-08-2007, 08:44 AM
Tropi-Care Chris's Avatar
The Tropi-Care TC-8 Swirl Cutter works great on plastic. I have detailed many F-bodies and restored the tail lights with a couple passes of the buffer.
Old 04-08-2007, 10:15 AM
Gipraw's Avatar
if you have a PC, you can do it that way, like Chris mentioned..
if you don't have a PC, then get some Megiuar's PlastX, and follow the instructions .. should fix yoru problem ..
if they are extremely damaged, then I would suggest wet sanding with Micromesh.. does a beter job than sandpaper.
Quick Reply: how to clean/repair swirl marks on tail lights?
