Front seat swappable?
Does anyone know if you can unbolt the bottom seat cushions on the front seats and swap them? I have major OUTSIDE leg sag in the seats. Thanks for the advice.
Copy & Paste Moderator
It can be done on the Formula seats. I've done it. The bottoms are identical. The only change to make it swap is to move a threaded clip from the right to the left side of the seat bottom (or visa-versa for the other side). I don't have pics, but you'll see what I mean during reassembly. My driver's side seat bottom is actually the seat bottom from the passenger seat. My driver's side seat bottom frame cracked and had to be welded back together. Hence the swapping. I needed to still drive the car while my father took the seat bottom frame to his friend for welding.
Again, that applies to the stock seats in my 2001 Formula. I don't know if its the same situation in the Camaro.
I am referring to ONLY the cushion. Not the entire frame. If this still holds true then I guess a TRUE swap might still be in question. Does anyone have a definite answer at all?
