Trans Am Aluminum trm gauge bezel
Have any of you Camaro owners installed an aluminum trim bezel in your gauge cluster? If so, what was involved in the installation and how did it turn out? I have an extra gauge cluster from a Camaro. If it will work, that saves me from cutting my original piece up. Thanks for the info.
How's it been going Brain? I just cracked my TA clear over when using the dremel to remove it. I noticed that the Camaro's clear plastic is open. Mine on the TA is glued onto the black plastic of the trim bezel
