Sponsored by: DashLynx
frc on fast intake
Old 06-01-2007, 09:08 PM
z28drag's Avatar
Default frc on fast intake
just a question? i have not seen this yet. do fuel rail covers fit with a 90mm fast intake. post pics if u have this set up....
Old 06-01-2007, 09:58 PM
AFASTYZFR1's Avatar
yes...here ya go
Old 06-01-2007, 11:11 PM
ghettocruiser's Avatar
Yes they "fit"... I put that in "" because dont expect them to lay right on the 90mm intake. In order to get mine to snap onto the fuel rail and onto the coil studs, I had to take material off of the "humps" in the cover. The FAST runners are wider and larger than the stock LS1 intake runners. So you need to trim them a tad to make it fit good. I used a 2" sanding drum on my drill. Made easy work and the 2" drum helped to keep the round shape.
Also you need to trim in the appropriate areas for them to clear certain objects in the engine bay.
Here is mine...just the drivers side. This is on an 87...but same idea. If you want, I can snap a closer pic looking right at the runners, but its pretty obvious what you have to do once you lay it on there.
AFASTYZFR1 you trimmed yours as well correct??
Justin
Old 06-01-2007, 11:35 PM
MESS's Avatar
those look good
Old 06-02-2007, 12:13 AM
HotWhipT/A's Avatar
I'll probably get some pics of mine when I get around to it. I have them all sitting in my room.
Quick Reply: frc on fast intake
