install clear corner?
Old 08-25-2007, 08:14 PM
Mex02Camaro's Avatar
Default install clear corner?
How do u install clear corners for 02 Camaro?
I tried searching but nothing came up. thanks
Old 08-26-2007, 12:33 PM
Loochy88's Avatar
remove your headlights (you have to undo one bolt on each, then twist them and turn them till they come out)
then the clears pretty much drop right in if i remember correctly. there may have been one other bolt in the way. i think it was a bolt or nut holding on the bumper cover. its really easy though.
Old 08-26-2007, 03:28 PM
Cobra2WS6's Avatar
I think you ment to say you slide the headlights towards the center of the car once you remove the 8m or 10m bolt (i cant remember which one it was)
Old 09-03-2007, 10:56 PM
The Postman's Avatar
i just installed mine and now i have to take them out b/c one is leaking and filled with water today when it rained ..i hate ebay ****
has anyone else has this problem...and also the main running light bulb is melting the bottom of the houseing....this is pissing me off majorly
Old 09-03-2007, 11:05 PM
99z28monster's Avatar
I got mine off ebay and have had them on for about two years now and no leaks. And it rains alot in hawaii
Old 09-03-2007, 11:06 PM
maybe i just got a dud...oh well i'll do some tweaking and have them good as new
