Anyone have pictures of an AEM wideband in a T/A center vent?
I searched with no luck. I'm thinking of getting an AEM wideband with the gauge and am considering putting it in the vents in the center of the t/a dash. The only issue is that the gauge is 2 1/16 in diameter and I'm not sure that's going to fit.
Thanks.
Thanks.
LS1Tech Sponsor
2 1/16" will be too small for the center vent so you will probably have to make some type of bezel for it to sit in there.
https://ls1tech.com/forums/showthrea...ts#post4090448
Page 3, Bad30th
Page 3, Bad30th
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
8 sec potential, 12 sec slip
My AEM wideband is in my pillar pod, but I have an aeroforce interceptor in my center vent location:
I used the cap of a krylon spray paint bottle. Trimmed it down and cut it at a slight angle so it faces the drivers seat a little more. Then cut out the 2 1/16 hole for the gauge. Then added some electrical tape to the outside of the cap to get a tight press fit into the vent hole.
