How To Install Hurst T Handle On A4 Ta
i just bought HURST T-HANDLE with thred size 7mm x 1.0 , 8mm x 1.25 , 10mm x 1.5 , 12mm x 1.5 .....but cant find the adapter to install to a4 shifter. any help will be appreaciated . thanx in advance .
As far as I know, there is only the 16x1.5 adapter that MBA made.
(It's our M6 stock pattern.)
You don't really have many options with the handle you bought.
Even if you try to tap the ****, it's impossible to find a 16x1.5 tap unless you go to a very good machine shop.
Your best bet is to return it if possible and pick up the correct one.
Before you buy another T-handle, read this also:
https://ls1tech.com/forums/showpost....42&postcount=8
