Sponsored by: DashLynx
Where are the codes at for paint
Old 06-25-2003, 08:11 PM
WhitePheonix's Avatar
Default Where are the codes at for paint
I just chipped alot of paint of my 96 birds bumper, I wanted to get touch up paint for it, but I need the code. Where do I find the code for the paint, where is it located on the car. I have artic white, but when I went to walmart there was like a hundred gm whites, and they had codes instead of names. thank you much!
Old 06-25-2003, 08:33 PM
HOTROD98Z's Avatar
Default Re: Where are the codes at for paint
It should be on your spid label inside the drivers side door, probably towards the end of your build codes and will be a number followed by the letter U, if you have any trouble you could always call the dealer with your vin and they can also tell you your paint code, hope this helps
