will these door panels fit???
ok i found a set of trans am door panels(99) that i want to put in my 98 camaro. will they fit? they do not come with the switches. will the camaro switches fit?(the small panel the switches are mounted to)
thanks guys
thanks guys
Re: will these door panels fit???
the switches will not fit direct. The plates are different, they might plug in, but you will at least need the firebird plates.
The door panels are not a direct swap, but will work, with a little modification.
There is a post somewhere, here, or ls1.com with more info.
Ryan.
Ryan.
Ryan.
Ryan.
http://www.ls1.com/forums/showthread...hreadid=321627
excellent. anyone know how much the switches are from the factory or anywhere else? looks like a do able project...
