Sponsored by: DashLynx
SLP grill install
Old 08-17-2003, 03:13 AM
hawaiiboysz's Avatar
Default SLP grill install
Has anyone installed the slp bowite grill. All I have is the grill what other kind of hardware is needed to install this grill. Any help would be greatly appreciated!
Old 08-17-2003, 08:03 AM
LS1Tech Co-Founder
Nine Ball's Avatar
Default Re: SLP grill install
Just a drill. They are somewhat of a pain in the *** to install. You have to push the grille on there hard and hold it in place, then mark the holes (two people make this easier). Then pull it back off and drill those holes perpendicular to the shape of the grille. That way when you push those plastic trees into them, they are flat on the surface.
Directions came with mine, forgot the hole size.
Tony
Old 08-18-2003, 12:07 AM
LawmanSS's Avatar
If you need the glossy plastic tree fasteners, they are available from the SLP engineering site...39 cents/ea, I think, you'll need 8.
www.slpeng.com
Quick Reply: SLP grill install
