Any way to adjust hood/headlights on T/As?
I've noticed my hood pins have slightly changed the lines of my WS6. One headlight rubs the hood, the gaps are uneven. How do you go about adjusting this? I've made sure the hood pins aren't rubbing the hood and pushing it over, and I've tried to loosen the headlight cover, but I can only get it to move up/down. Any ideas? Thanks for any help!
Re: Any way to adjust hood/headlights on T/As?
With the headlight in the down position, you will notice a black bracket(red in my pics) that holds the the headlight in its spot. Loosen those 2 bolts and you can slide the entire assembly forward or backwards. With the headlight up, there are screws that position the headlight cover itself in place.
click for close ups
click for close ups
