early 6.0 an tranny ?s
Ok I have a 6.0 from a 99-00 truck well I know you cant run the 4l60e on it cause the crank. YOu can run the 4l80e or th350 or th400, My ? is can I run a 700r4? I should beable to right since the 700r4s can be replaced with a th350. I really want this 6.0 in my car but dont want to put in a 3 speed. Thanks for the help
LS1Tech Sponsor
Actually you can run the 60e in either the lt style or the lsx style engines it was made in both types the lt-1 would be the 350 400 700r4 and 94 -97 4l60e and some after that i trucks that did not use the LSX style bolt flange .
You can use any of these,
__________________
Thanks performabuilt. My prob is on the early 99-00 6.0s the crank sticks out about a 1/4 to 1/2 further out which makes it not able to run the 4l60e that my 98 z28 has in it. So im just going to get me a 700r4 an have it built. I dont want to lose my overdrive
