Dual TH400 cooler
Dual TH400 cooler
I'm doing the TH400 swap this month and wondering if I can re-use my B&M coolers that I already got on my 4L60 without any change in inlet/outlet lines or fittings?
I run dual 70264
http://store.summitracing.com/partde...5&autoview=sku
Thanks in advance
I run dual 70264
Thanks in advance
As long as the hoses you have fit on the fittings on the th400, I don't see any problems
However, I think 2 coolers is a tad overkill. I read on here a while back that a guy did tests with 1 cooler vs 2, and having the second one didn't really help a whole lot
I have just a single cooler (with a built on fan) on mine, and it always stays within the right ranges (~150-180)
Yea you can run them. You can always change the fittings out on the turbo 400 to match the size on your coolers. Or you can get a brass hose adapter, you can make for sure make it work.
I run two coolers on my th350. One has a fan and one is a frame rail cooler. In the summer time it needs them when I'm in traffic.
